I am trying to hide some components in a view, but from the view itself I am able to hide only edges.
I remember something about changing the selection priority to part priority, but I have no memory how to do it.
Can somebody explain to me?
Thank you in advance.
Solved by kacper.suchomski. Go to Solution.
Hi
Change the selection priority (Shift + RMB or quick access bar).
Kacper Suchomski
Hi
Kacper Suchomski
Sorry, I don't get it.
What is RMB?
Where is the quick access bar?
What is RMB?
1. Right mouse button.
2. At the top of the program window.
These are not Inventor terms, but computer terms.
It is also worth checking the forum before starting another thread on the same topic.
The marked solutions serve subsequent users and adepts.
Kacper Suchomski
Kacper Suchomski
Good for you if you are familiar with those terms. I am not and I am not good at abbreviations.
FYI, I already checked the forum and couldn't find the answer I was looking for.
You don't need to use a tone like I am bothering you, it's not necessary.
Next time ignore my post.
Have a nice day.
Have a nice day.
Hi! I bet the drawing view is associative to a design view. Edit the drawing view -> uncheck "Associative to DV" box. Then the components can be made invisible in the drawing view.
Many thanks!
Many thanks!
Thank you.
