Hello, can somebody please explain to me why I can't flatten sheet metal part "Part combined"?
When I do the features individually I can make a flat pattern, see "Part flange" and "Part roll". But when I combine those features in one part "Part combined" it doesn't work...
If this is a limitation of Inventor, can someone tell me if it does work in Inventor 2025?
I'm using Inventor 2021.
Solved by kacper.suchomski. Go to Solution.
Hmm, it works for me.
Kacper Suchomski
Thank you for the video, that confirms it does work in Inventor 2025. We plan to update to version 2025 within two months, so for now I will use a simple alternative.
This is the error I'm getting in Inventor 2021:
First try flattening the collars by hand using Unfold (not Unwrap)
Kacper Suchomski
That also doesn't work unfortunately. Inventor 2021 doesn't recognize it as a bend, but as a roll, because of that it can't be flatten.
