Inventor Forum
Hi! One more issue with dimensioning.
3 REPLIES 3
373 Views, 3 Replies
Hi!
I use the following tutorial
https://www.youtube.com/watch?v=gFWAy_wnoZc
At 41:45 sketch 16 is fully constrained
In my case having the same dimensions one more dimension is still required.
I tried to use auto constraining.
it shows that this dimension is required.
I am confused, because the author doesn't use it .
The file is attached.
Thank you in advance!
3 REPLIES 3
JDMather
Missing Tangent Constraints.
It is always preferable to use appropriate Geometry Constraints over dimensions when possible.
I recommend that you forget you ever saw the Autodimension/Constraint tool.
When something shows as underconstrained - start dragging endpoints.
You should see obvious visual indication of missing constraint.
As you gain experience - Inventor will add nearly all of these constraints for you as you are sketching - so it isn't extra work.
mwighton
if you watch closely he get the arc to be tangent to the outside projected line before creating the arc. then tangents it to the already existing arc.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
in reply to: mwighton
Thank you!!
