Hi!
One more issue with dimensioning.
I use the following tutorial
https://www.youtube.com/watch?v=gFWAy_wnoZc
At 41:45 sketch 16 is fully constrained
In my case having the same dimensions one more dimension is still required.
I tried to use auto constraining.
it shows that this dimension is required.
I am confused, because the author doesn't use it .
The file is attached.
Thank you in advance!
Solved by mwighton. Go to Solution.
Solved by JDMather. Go to Solution.
Missing Tangent Constraints.
It is always preferable to use appropriate Geometry Constraints over dimensions when possible.
I recommend that you forget you ever saw the Autodimension/Constraint tool.
When something shows as underconstrained - start dragging endpoints.
You should see obvious visual indication of missing constraint.
As you gain experience - Inventor will add nearly all of these constraints for you as you are sketching - so it isn't extra work.
