hexagonal in a tube
hexagonal in a tube
Message 1 of 15
hexagonal in a tube
I am new here on the discussion board.
I need some help to draw a hexagonal in a tube "like a catalyst from your car is".
The main idea is to print it in 3D.
I tryed to draw a hexagonal in a tube "Diam: 80 mm, Length 100 mm.
I can draw the hexagonal BUT I am not succeeding in it to draw them in a circel.
Any help I appreciate ...
Thank you,
Dimaxum
Replies (14)
Message 2 of 15
JDMather
@Anonymous wrote:
I can draw the hexagonal ...
Attach your *.ipt attempt here.
Message 3 of 15
JDMather
Where did you go?
This should only take 4 minutes - looks like you have been working on this for 4 months
http://forums.autodesk.com/t5/autocad-for-mac-general/drawing-a-hexagon/td-p/5932392
You will have to respond to questions to get the solution.
Message 4 of 15
Hi JDMather,
Thank you for responding to my question.
As you maybe could see or find here on the discussion board, is that I ask this question and help befor.
The problem is that I can create the hexagonal, but I can't manage to get them in a circel that they realy fit fot 3D printing.
This picture is what I talking about.
The heagonal must be 5 mm and the diameter of the circel that ALL of them fit is ø80 mm the lengt "hight" is 100 mm.
I hope that I am clear enough, if you have any questins in matter to my discribtion please let me know.
Kind regards,
Dimaxum
Message 5 of 15
HI JDMATHER,
Also I got this dwg file And tryed to manage as discribed in my earlier post to you.
Dimaxum
Message 6 of 15
mcgyvr
See if this helps..
https://forums.autodesk.com/t5/inventor-general-discussion/is-there-an-easier-way-to-make-a-honeycom...
I can't think of any "tricks" to only constrain the pattern to an outer circle right now..
I guess "adjust" with rectangle pattern
Maybe this is acceptable..see attached 2016 file..
Message 7 of 15
Hi mcgyvr,
Thank you for the responce ... but I can open the ipt file.
A error code says that it no longer is supported bij Apple X11 to open it.
Can you post a file I can open in Invetor Fusion or AutoCad 2015.
Thank you.
Dimaxum
Message 8 of 15
JDMather
Is your question an AutoCAD question or is it an Autodesk Inventor question?
What version of Inventor are you using?
Message 9 of 15
In AutoCad
Inventor 2012 version 576.10
Dimaxum
Message 10 of 15
JDMather
Are you a student or commercial user?
Can you post a screenshot of your "Inventor 2012"?
Message 11 of 15
I am a student on the university of Leuven.
Thank you for your intest an try to help me.
Dimaxum
Message 12 of 15
JDMather
Students can get Inventor 2016 for free at this site http://www.autodesk.com/edcommunity
It would be much easier to communicate with a more recent release of the software.
Message 13 of 15
mcgyvr
Since you have an old version of Inventor you won't be able to open anything I send you.
This screencast should show you how I did it though.
Message 14 of 15
Hi again,
I work now on AutoDesk Fusion 360.
In this drawing as he picture is showing I see a view wite dots in the drawing.
How do I deselect them?
How can I fit the Honey Combes in the Tube of ø80 mm and closing (not that they get out of the circel.
Any Tips ore Hints are most welcome.
How can I post a file that you can download and load up in your application to investigate?
Thank you for your time and effort.
DimaxumHoney Combe in Tube
Message 15 of 15
mcgyvr
@Anonymous wrote:
Hi again,
Dimaxum
Wrong forum now.. Fusion forum is here
https://forums.autodesk.com/t5/fusion-360/ct-p/1234
