Hello Everyone,
I try to do some flange but I want that the flange follow 1 line ..
I need 1 flange 4" x 37-1/4"
In the same direction of the line
I don't know if you understand what I want to do
Thank you 🙂
Attach your *.ipt file here and end all doubt.
Sketch1 is unconstrained (floating in space)?
How did you get a 100° angle without a dimension?
Did you attach the correct file? The file you attached does not look like the image you posted above?
Have you installed Service Pack 1 and Update 1?
@Anonymous wrote:
No I try on my computer to install them but when I click to install it's an error ....
I edited my response above.
Did you post screen shot of the error on install of SP and resolve the problem?
So now we have multiple problems to solve.
I don't see this line in your file?
@Anonymous wrote:Sketch1 is unconstrained (floating in space)?
The image are exactly like the .ipt ....
do you understand what I want to do ?
and wait a minute for the error I will refind the files ....
@Anonymous wrote:
@Anonymous wrote:No I try on my computer to install them but when I click to install it's an error ....
I will Send you another one wait
What I need to do is a flange like that
But what I want to know is If I can do the flange only with 2 line
If I can click on my line of 4" and said that I want I flange of 4" x 37-1/4" in the direction of the line 37-1/4"
do you undestand ?
sorry for my english I speak french..
I think that I solved my problem with the update ...
I install the service pack to put them in english and the update don't want to update my software because it's I pack in french but I do the upadtae with my inventor open and the update changing automatic in english ...
but with the flange my porblem is not solved
@Anonymous wrote:
....but with the flange my porblem is not solved
You have not attached the same file that you showed in your image.
