Hello everyone.
I am having an issue with the rip of the cone (part is attached).
It seems that the rip command doesn't work. I modelled the cone by revolution and loft/shell commands and then tried Rip but without success.
What do I do wrong?
Best regards,
Sergey
Solved by Sergey_Dukman. Go to Solution.
I have found the solution:
Cone should be made as sheet metal by using the Loft flange method (Die Formed).
Then Rip does work well.
Best,
Sergey
Hi Sergey,
I am glad that you find a workaround using Lofted Flange. Actually, your original part would have worked. The issue was the the Shell creating the faces non perpendicular to the Sheet Metal face. As a result, the Rip does not work properly.
Instead of Solid Loft, you could create the Loft as a surface (or use Delete Face to turn the solid into a surface). Then thicken it by the thickness. After that, Rip will work.
Many thanks!
