Help understanding basic constraints
michael.dockseyFCG86
Message 1 of 12
Having used Solidworks the concentric and mate constraints only do one thing. In Inventor a concentric constraint can do different things. How can Inventor just do a consentric constraint without a mate??????
Replies (11)
Message 2 of 12
JDMather
@michael.dockseyFCG86 wrote:
 How can Inventor just do a concentric constraint without a mate?
(edited)
I don't understand your question, can you elaborate?
Message 3 of 12
I am looking for a full tutorial on how to use the assembly constraints. When I insert a bolt into a hole sometimes it gives me only a concentric constraint and other times it gives me both a concentric and a mate. What am I doing different? Many thanks
Message 4 of 12
JDMather
Can you Attach example files?
Message 5 of 12
I am trying to constrain the seal in the groove. Many thanks.
Message 6 of 12
CGBenner
Were you trying to attach a file?  There is no attachment to your last message.
Chris Benner
Message 7 of 12
[cid:[email protected]]
I need to insert item 18 into the 5 sided slot. Many thanks
Message 8 of 12
JDMather
You cannot Attach files here via email reply.
You must Reply using the web forum.
Message 9 of 12
CGBenner
There is still no file attached.  When you reply, scroll down until you see this:
If you are trying to attach an image, use the camera icon on the reply menu at the top.
Chris Benner
Message 10 of 12
Files attached. Apologies for them to be missing.
Message 11 of 12
JDMather
Do you see them Attached here?
Reply to Message - Autodesk Community
Message 12 of 12
Gabriel_Watson
Maybe for your needs you should be using the Insert > Aligned constraint. It will do more than simply constrain the axis of the objects, so it saves you some time when you have to add bolts to holes, for example:
More about constraints under here:
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-198F05E4-2973-4818-8F25-A0B8B9796D07
