I just need to extrude a circular area along the y axis. But it seems impossible, I've tried to remake the whole project and try again but it didn't work. I wonder why Inventor makes a such simple process like that impossible to do, I watched at least 30 tutorials on YouTube and still couldn't do this basic thing.
Solved by SharkDesign. Go to Solution.
You've made this far more complicated that it needs to be.
First you should probably do some tutorials because it looks like you are coming from a background that is not 3D solid modelling.
You don't need the 3D sketch, just use a 2D one.
You don't need any of those boundary patches.
Start again and model it simply.
follow this
https://knowledge.autodesk.com/community/screencast/b78e6f5a-6c9d-4957-af69-34cf17c14491
Hi Leonardo,
There are several ways to do this. The profile is a 3D sketch. You can use Ruled Surface (3rd option) to protrude it in a given direction. Then use Sculpt or Stitch to solidify the surfaces.
Or, you can thicken the Boundary Patch surface. Or, project the 3D sketch to 2D and then Extrude.
Many thanks!
