Inventor Forum
Visibility
5 REPLIES 5
lkirit2000
787 Views, 5 Replies
Visibility
Hi
Please see the attached image and CAD file. I need to hide the yellow edge . If try to hide the 2D sketch the text also hide, but I want to show the text.
Is there any other way to hide the line without hidng the text ?
Labels (1)
5 REPLIES 5
JDMather
in reply to: lkirit2000
What is the purpose of the text?
Emboss the text or delete the projected edges.
lkirit2000
in reply to: JDMather
Hi
Thanks for your prompt response.
The purpose is to show as image only not to show lines.
SBix26
Edit the sketch, select the lines, Delete.  Unless they're needed for your sketch, they can be removed.
If projected edges are needed to locate the text, you can locate a sketch point by dimensions from projected edges in one sketch, then create a new sketch with a projected point from the previous sketch, and the text attached to that point.  Then make the first sketch invisible.
Sam B
Inventor Pro 2022.0.1 | Windows 10 Home 20H2
LinkedIn
SharkDesign
Do the above, or if you want it to show on your drawing/renders as well, use emboss and type a very tiny amount to extrude, like 0.0001mm
  Expert Elite
  Inventor Certified Professional
johnsonshiue
Hi! Maybe you want to disable "Autoproject" options. Go to Tools -> App options -> Sketch 0> uncheck "Autoproject edges during curve creation" and "Autoproject edges for sketch creation and edit."
For existing projected sketch geometry, you will need to delete it. It won't be created automatically next time.
Many thanks!
Software Test Engineer
