Inventor Forum
Help... Drilling a hole in a cylinder
10 REPLIES 10
Message 1 of 11
2690 Views, 10 Replies
I am doing my GCSE's and i am making a microphone stand, for the base to hold the foldable legs I need to drill a hole in the cylinder which is the shape, I know how I would do his in the workshop but I don't know how I would do it on Autodesk Inventor 11, please help.
10 REPLIES 10
Message 2 of 11
If this post is in the wrong thread then please point me in the right direction, I really do need to know asap.
Message 3 of 11
Drill on a flat plane.
wrote in message news:6016879@discussion.autodesk.com...
Message 4 of 11
Assuming there are two origin work planes going the length of the cylinder through the centre, select work plane, click one of
the origin work planes and then click the outside of the cylinder. Now select Sketch and click the work plane you created.
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be
as mad as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
11, please help.
Message 5 of 11
markc-uk
Easy one this. Ensure the cylinder you want to drill is based around the origin. Expand the origin folder and turn on the visibility of the groundplane that is perpendicular to the hole you want to create.
Click new work plane tool, then click the visible ground plane, then click a point on the exterior surface of the cylinder.
You then have a user defined workplane tangent to your cylinder's surface. Start a new sketch, click your tangent workplane. You can then project any geometry through, create a point, constrain and dimension the point exit the sketch and then hit the hole command.
Check the help for work plane reference and see "Work plane tangent to a cylinder"
Message 6 of 11
markc-uk
Grr. Mr Anderson beat me to it and included a fancy screenshot 😉
Message 7 of 11
Cheers, now i will be able to finish it off, should be done by the end of the week...
Message 8 of 11
thank you as well ^_^
Message 9 of 11
A bit late, but here's a handy document on work features (attached).
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
Message 10 of 11
What's this "Mister" thing ;~0
Duncan
wrote in message news:6016957@discussion.autodesk.com...
Message 11 of 11
JDMather
>...should be done by the end of the week...
Be sure to post your finished pic on Friday.
