Having trouble removing DIN rail from a .stp file - Inventor
amelanconNRFW8
Observer Observer
amelanconNRFW8
Observer
Observer
For my design, I need a Prosoft card, but when I download the .stp file and open it in Inventor, a DIN rail is attached to it. The issue I am seeing is that the DIN rail and ProSoft card are a part of the same solid body. Any help or advice would be greatly appreciated. I am pretty new to Inventor. I tried splitting it, I tried deriving the part, but nothing is working. Unless I am doing those steps wrong. The reason I need to remove the DIN rail is that I am putting the Prosoft on a different DIN rail when I bring it into my assembly drawing.
@amelanconNRFW8 Your post title was modified to add the product name and moved to the Inventor forum to increase findability - CGBenner
kacper.suchomski
Hi
You can use Delete Face tool.
Kacper Suchomski
SBix26
If you can't figure it out, post the .stp file here and someone can help.  What version of Inventor are you using?
Sam B
Inventor Pro 2026.1 | Windows 11 Home 24H2
