Configurable model with cut-outs.
sj_kohlmann
sj_kohlmann
We have a wooden house with vertical planks. My goal is to have a BOM with the total length of each plank and all combined.
The variables:
- the two windows change in size and positioning
- all the vertical planks can slide left or right
Planks can be from top to bottom, cut in 2 planks(1+2) or are cutout (3)
How would you set this up?
johnsonshiue
Hi! I would use iLogic for this design. First, I would focus on creating one parametric model (using Frame Generator or Skeletal Modeling approach). Second, create an iLogic rule to drive the parameters. Use iLogic Design Copy to spawn variations.
Many thanks!
Software Test Engineer
