Inventor Forum
Fill in void
3 REPLIES 3
ZaC-04
249 Views, 3 Replies
Fill in void
What method do i use to fill in the 6 voids on the inside of the bottom of the tank [plate supporting legs]. The voids were created when i use shell feature. I tried using different thickness with shell feature but not work.
How would you fill in these voids please
2024 file attached
Zac
3 REPLIES 3
in reply to: ZaC-04
1 create surface by edges
2 command sculptor
blandb
in reply to: 89198826955
Delete Face and make sure to have the Heal remaining faces checked. Selecting the perimeter faces, could also select the internal arced faces
Autodesk Certified Professional
SBix26
in reply to: ZaC-04
Even easier than adding a new feature or two at the end, edit Thicken1 and make it a new solid, then edit Circular Pattern2 and add that new solid to the pattern.  Now the reinforcing pad is not part of the Shell feature.
Sam B
Inventor Pro 2025.1 | Windows 11 Home 23H2
