"All I want to do is have a form pop up when the part is placed that allows us to enter the new name at that point to both save time and prevent accidental overwriting of the original, which I agree should be locked down better. I can make a form pop up when the part is placed my question is, Is there a way I can link the "save as" function to the form?"
Sorry, I meant Save Copy as.
I understand the advantages of Iparts but With the complexity of our parts, the automation program that mostly puts our assemblies together, and the ease of our "Panel Editor" tool they are just not the best fit for our current needs.
As an example we will use the wall panel again since it is the simplest panel we have, there are both male and female genders for each side of the wall panel that can be changed as needed. there are standard and reversed lock arrays that the user can turn on and off by selecting the number of each that they need in Parameters with rules that will not allow more locks to be turned on than will fit the size panel they are on, and much more. I could go on but you can begin to see that the number of coulombs in an IPart would become cumbersome not to mention that our automation program would not be able to modify the parts if we were to make them into IParts.
I know that I can add a form that pops up when a panel is placed into an assembly and I can make it display a field that allows me to change parameters but I need it to change the parts name.
So, I am back to my original question. Is there a way I can link the "save Copy as" function to the form? or another way to prompt a "rename / save copy as" when placing a panel.
