Plot in Inventor
Plot in Inventor
Plot in Inventor
Could someone give a little advice please.
Having placed a assembly base view onto a drawing sheet, I am am trying to print the drawing in colour, this is something I have done several times before in other projects without any trouble. however in this instance when when I preview the plot, the coloured assembly is shown on a black  background to the extents of the base view box. Having checked on other drawings that printed ok they now have the same problem. plotting only in black and white is fine. to my knowledge I have not made any alterations to the original settings.
I am using Inventor professional 2016.
Been hours now trying to to sort trying to sort the problem.
Any help would be appreciated.
Best Regards to all
mdavis22569
Did anything change in the properties:
Mike Davis
Many thanks for your reply, however nothing has been changed in my printer settings,
 Bevan
mdavis22569
Can you share an image or screencast?
Mike Davis
Many thanks for your replies, problem solved in print settings although how the change came to be made I do not know must have been done inadvertently . Unfortunately  at the moment I do not know how to take and post a screen cast in Inventor. this is my next project for myself and in order to help others if possible. Probably my next post.
once again thank you for your help.
