Before our rollout of Inventor 2018 this weekend, one of our users took the time to export his custom settings from 2017 from the Tools->Customize dialog. He had a number of custom key bindings he wanted to preserve. On Monday he imported the settings into his freshly installed copy of Inventor 2018 (w/ 2018.0.1 update). AFAIK importing these settings from a previous version is meant to be supported.
Well, this had terrible consequences. For one thing, the Vault tab became badly broken. Both the Log In and Log Out buttons were grey at the same time; only the Open button was not greyed out. Clicking Open presented the Log In to Vault dialog; but as soon as the login was completed, Inventor crashed w/ the error report dialog, every time.
Furthermore, clicking Finish Sketch on the simplest possible sketch (on a standard plane in an empty part) immediately crashed Inventor every time. There may have been other problems, but we moved him to a spare workstation for the rest of the day.
Investigating the broken Vault tab led me to find that the important EDM add-in was unable to load. Looking into that detail led to a Vault forum topic "Vault buttons are greyed out" where user chrisjuk12 pointed out that user profile corruption can lead to EDM not loading. We backed up and deleted Inventor and Vault related folders in the user's AppData\Roaming folder and users's HKCU\Software\Autodesk\Inventor key in accordance with chrisjuk12's suggestions, and the problem was solved.
Since the only thing this user had done differently from our 12 other users was import his customization settings, I took the XML file he'd exported from 2017 and imported it on a spare workstation running Inventor 2018. The impact was exactly the same: same symptoms on the Vault tab, same crashes after finishing sketches.
Thought I would post our experience here in case other users are having this problem. I would attach the XML settings file, but that doesn't seem like a good idea as it's pretty much toxic to Inventor 2018. The file itself does not seem to be corrupted in any way -- it's a complete XML file down to the closing tag. I have forwarded it to the Inventor CER Report address in a reply to the automated CER email generated by one of his crashes.
