I modelled a blade where it twists between the center hub and blade. How do i get a more accurate shape flow where the twist and blade connect? [Image attached with red circles highlighting the sections]
Is there a twist feature to create this blade shape or a better method than i have used?
Inventor 2022 part file attached
Zac
I did use the Loft [join] originally but it created differences in thickness which is why i used Loft [surface & thicken]. Even if i use a greater distance between the 2 sections the thickness varies. The original part has a small distance between the hub/blade.
Zac
