Inventor Forum
Fan Blade twist
4 REPLIES 4
ZaC-04
377 Views, 4 Replies
Fan Blade twist
ZaC-04
I modelled a blade where it twists between the center hub and blade. How do i get a more accurate shape flow where the twist and blade connect? [Image attached with red circles highlighting the sections]
Is there a twist feature to create this blade shape or a better method than i have used?
Inventor 2022 part file attached
Zac
Fan Blade twist
Zac
4 REPLIES 4
in reply to: ZaC-04
89198826955
my opinion
1.make a "loft" between two faces
2.tab "conditions"
3.OK
my opinion
2.tab "conditions"
3.OK
ZaC-04
in reply to: 89198826955
ZaC-04
I did use the Loft [join] originally but it created differences in thickness which is why i used Loft [surface & thicken]. Even if i use a greater distance between the 2 sections the thickness varies. The original part has a small distance between the hub/blade.
Zac
Zac
chris
in reply to: ZaC-04
chris
@ZaC-04 if this part doesn't need to be parametric, then this is an easy thing for "Plasticity" to handle.
in reply to: ZaC-04
89198826955
create surfaces
make the thickness
create surfaces
make the thickness
