Lately, I have been encountering an issue where I try to do an extrusion or revolve that is located somewhere in space and the extruded solid shows up at the origin rather than where the sketch defines it. In this case sometimes the solids don't even show, just the outline when you hover over them in the tree.
Solved by hithere8. Go to Solution.
Solved by JDMather. Go to Solution.
