Working with a student to make this simple coil we ran into an issue where the coil is turning out as a surface Body or something. The design/modeling process is straight forward but when this students sketch is being converted, it is different. why is this happening?
coilmck is the error file coil111 is what we want
Solved by CCarreiras. Go to Solution.
Hi!
There's no problem, you just selected to create the feature as surface.
After creating, you can't go back to solid, so delete it (maintain the sketch), and select the output as solid... check the video.
