Inventor Forum
EXPORT XLS TABLE TO PDF - Inventor 2018 problems
64 REPLIES 64
Message 1 of 65
marcin_bargiel
3554 Views, 64 Replies
marcin_bargiel
I've found problem with export to pdf -  drawing with Excel table where is VERTICAL text.
Please look at exported pdf - inventor 2017 and exported pdf made by inventor 2018.
I tried with Excel 15 and Excel ver 16 (2013 & 2016) - the same WRONG results...
Vote for REPLACE VARIES !
REPLACE VARIES
REPLACE VARIES
64 REPLIES 64
Message 21 of 65
marcin_bargiel
marcin_bargiel
Did You update windows and inventor?
I tried on different PC with win8, excel 2016, inventor 2018.1 - everything
is working OK !
REPLACE VARIES
is working OK !
REPLACE VARIES
Message 22 of 65
marcin_bargiel
marcin_bargiel
is working OK !
REPLACE VARIES
is working OK !
REPLACE VARIES
Message 23 of 65
in reply to: marcin_bargiel
Thank you for answering, I made a mistake and thought the forum was for 2017 not 2018 but other designers had the problem a couple of months before I did, and yes I had the latest windows and inventor updates for 2017and everything was good until Tuesday.
Message 24 of 65
marcin_bargiel
marcin_bargiel
Hello again !
After last inventor update 1.1 excel table came back !!!
But vertical text still is not shown good ! 😕 😕 😕
REPLACE VARIES
Hello again !
REPLACE VARIES
Message 25 of 65
marcin_bargiel
Dear developers, is it such a difficult task?   When is the chance that it will be corrected?
REPLACE VARIES
REPLACE VARIES
Message 26 of 65
johnsonshiue
Hi Marcin,
The issue has been fixed in our internal build targeting 2018.2 Update. The Beta version of the Update is available for tryout purpose. You can sign up Inventor Beta Program at https://bit.ly/InventorBeta.
Many thanks!
Software Test Engineer
Hi Marcin,
Many thanks!
Message 27 of 65
marcin_bargiel
Thank You Johnson ! When will this version be released?
REPLACE VARIES
REPLACE VARIES
Message 28 of 65
johnsonshiue
Hi Marcin,
I am sorry that I cannot comment on the exact release date of 2018.2 Update. You could go to Updates download page and get an idea of prior update release dates. It might be a good indicator for future updates.
Many thanks!
Hi Marcin,
Many thanks!
Message 29 of 65
marcin_bargiel
Dear Johnson
I am very disappointed, I've checked the beta version 2018.2 (TURBO), the vertical text is not properly displayed again... 😕
Please look at attachment...
REPLACE VARIES
Dear Johnson
REPLACE VARIES
Message 30 of 65
johnsonshiue
Hi Marcin,
Any discussion about Beta build should happen within the Beta forum. The behavior you are describing does not sound right to me. Could you report it as a problem on Beta site?
Many thanks!
Hi Marcin,
Many thanks!
Message 31 of 65
marcin_bargiel
I installed yesterday inv 2018.2 -  there is still the same problem (with so simple thing !)
on inv beta forum, there is no discussion - nobody anwer to my question ... 😕
I regret but this is my last year with Autodesk
REPLACE VARIES
REPLACE VARIES
Message 32 of 65
johnsonshiue
Hi Marcin,
I am sorry that I am a little bit confused right now. There must be an environmental difference. I tried the two drawings you provided on this thread. They seem to be exported to PDF in 2018.2 properly (see attached). Could you go to Help -> About and make sure you have 2018.2 Update build 217 installed?
Many thanks!
Hi Marcin,
Many thanks!
Message 33 of 65
marcin_bargiel
I have build 227 (not 217)
REPLACE VARIES
REPLACE VARIES
Message 34 of 65
johnsonshiue
Hi Marcin,
Yes, it should be build 227. You do have the 2018.2 Update installed. Did you take a look at the pdf files I attached? They seem right to me. I cannot explain why you are not seeing the fix. I will work with the project team to understand the behavior better.
Many thanks!
Hi Marcin,
Many thanks!
Message 35 of 65
marcin_bargiel
I've got office 2013 updated (polish version), inventor updated (english version)
Please check my files once again. As You can see, everything is good in xlsx file, and dwg, when export to pdf there is a problem !
REPLACE VARIES
REPLACE VARIES
Message 36 of 65
marcin_bargiel
one more picture
REPLACE VARIES
one more picture
REPLACE VARIES
Message 37 of 65
marcin_bargiel
Could You please send me Your xlsx file (english version) to try...
REPLACE VARIES
REPLACE VARIES
Message 38 of 65
johnsonshiue
Hi Marcin,
The pdf files were exported from my machine with your Excel files. Something is missing. I have checked with the project team. Indeed, there is still a unsolved issue here. It is not fixed in 2018.2. I am sorry for the earlier confusion.
Many thanks!
Hi Marcin,
Many thanks!
Message 39 of 65
in reply to: johnsonshiue
It has been two months since this was last commented on, any updates as to when it will be fixed?
Message 40 of 65
johnsonshiue
johnsonshiue
Hi Guys,
I will check with the project team to get an update on the issue. So far, it does not look like it has been resolved. FYI, this public forum is mainly for discussion purpose. It is not a replacement for Autodesk Product Support services. If you have time-critical issue or you have reported a case, please contact Autodesk Product Support for assistance.
Many thanks!
Hi Guys,
Many thanks!
