Hi
When renaming a parameter i.e. changing changing the name d0 to side1, changing d1 to side2 etc. the new parameter name isn't displayed. The only way I can get it to display is to close the parameter dialogue box and re-open it.
Step 1: Rename parameter
Step 2: Press Enter (note how d0 returns)
Step 3: Close the dialogue box and re-open. Now d0 has been changed to side1:
Is this a bug or have I just missed it in previous versions?
Solved by johnsonshiue. Go to Solution.
Hi! This is a known issue. 2021.0.1 contains a fix to address the issue but it introduces another issue. It should be fixed in 2021.1 update. It will be available soon.
Many thanks!
Would it been fixed in the 2021.1 that was released on 12 July?
The release notes dont seem to indicate it's been addressed.
Thanks!
Hi! Yes, it should have been fixed on 2021.1. Please install it and try it out. Report back the findings.
Many thanks!
Yep, all working in 2021.1. Curious to know though what other issue the 2021.0.1 introduced....
Hi! The regression in parameter naming and compute is the only issue we are aware that 2021.0.1 introduced.
Many thanks!
