Inventor Forum
EXPORT XLS TABLE TO PDF - Inventor 2018 problems
64 REPLIES 64
Message 1 of 65
marcin_bargiel
2895 Views, 64 Replies
I've found problem with export to pdf -  drawing with Excel table where is VERTICAL text.
Please look at exported pdf - inventor 2017 and exported pdf made by inventor 2018.
I tried with Excel 15 and Excel ver 16 (2013 & 2016) - the same WRONG results...
Vote for REPLACE VARIES !
REPLACE VARIES
64 REPLIES 64
Message 2 of 65
Jon.Dean
in reply to: marcin_bargiel
 Hi Marcin,
Thanks for reporting this issue. I will double check on my computer and then log it with development.
Thanks again.
Jon.
Jon Dean
Message 3 of 65
Jon.Dean
Hi Marcin,
Can you attach the drawing you used to create the PDF files?
Cheers
Jon.
Jon Dean
Message 4 of 65
Jon.Dean
Hi Marcin,
I am not able to reproduce, check out my screencast.
Is your workflow the same?
Cheers
Jon.
Jon Dean
Message 5 of 65
marcin_bargiel
in reply to: Jon.Dean
Thanks John for Your response.
I've created new excel file and dwg/pdf files - still the same problem 😕
Maybe i need to change some settings in inventor ?
Marcin
REPLACE VARIES
Message 6 of 65
Jon.Dean
Hi Marcin,
OK, so I see the difference between my Vertical text and your Rotated 90 degrees Text.
This is a known issue and I suggest you use Vertical text and shown in my screencast until we get a fix.
I have linked your case to the change request.
Cheers
Jon.
Jon Dean
Message 7 of 65
marcin_bargiel
Thank You Jon, I hope They will make changes soon...
It works good with inventor 2017.
REPLACE VARIES
Message 8 of 65
TRAGEDY !!!
After installing upade today, when i export drawing with xls tables - i DO NOT SEE ANY TABLES in pdf !
Is worse than it was!
Autodesk do not go this way please !
REPLACE VARIES
Message 9 of 65
Hi Marcin,
I have confirmed the behavior. The Excel table with vertical text in drawing still fails to export to PDF properly even on 2018.1 Update. The fix is not yet available. I will work with project team to understand the behavior better and fix it as soon as we can. I am very sorry for the trouble in the meantime.
Many thanks!
Software Test Engineer
Message 10 of 65
I'm not talking about vertical text now, I'm talking about excel table at
all ! when export to pdf, there is NO VISIBLE ANY TABLE.
REPLACE VARIES
Message 11 of 65
Hi Marcin,
The behavior is different than what I see on my machine. The bad behavior I am seeing is specifically about the vertical text in a table. Could you send me an example?
Many thanks!
Message 12 of 65
mcgyvr
@marcin_bargiel Have you tried loading a free PDF printer like Cutepdf and using that instead of Inventors functionality?
http://www.cutepdf.com/Products/CutePDF/writer.asp
That way you don't have to wait on Autodesk to fix their bugs.
But I will say that I have no problems with 2018.1 and exporting a PDF containing an xls table placed via paste special or insert object..
So its specific to your machine/files and not a global issue..
Message 13 of 65
Example attached
REPLACE VARIES
Message 14 of 65
marcin_bargiel
in reply to: mcgyvr
External (virtual) pdf printer working good - as always !  i use pdfcreator
 I can't understand that Autodesk instead of improving product - it makes it only worse - when it comes exporting to pdf off course... 😉
REPLACE VARIES
Message 15 of 65
mcgyvr
Example attached
@marcin_bargiel
I can confirm that when I open your dwg file and export to PDF the table does NOT show in the PDF..
What program did you use to create that xls file? And what version?
Did you use "inert object" or paste to get the excel table into the dwg file..?
Please include ALL details/steps you use as the problem is specific to the exact workflow/method in which you are creating that table..
Please be VERY specific so this bug or issue can be fixed..
Message 16 of 65
marcin_bargiel
in reply to: mcgyvr
MS Office 2013, version 15.0.4945.1001 (current)
Windows 10 (current, updated few days ago the same as inventor)
Inventor 2018 (current)
Yes I used "insert object", I tried with file .xlsx and older version of
file .xls
REPLACE VARIES
Message 17 of 65
marcin_bargiel
in reply to: mcgyvr
file .xls
REPLACE VARIES
Message 18 of 65
excel files...
REPLACE VARIES
Message 19 of 65
mcgyvr
excel files...
Some specific details are still missing..
I tried using the dwg file you provided above and the 2 xls and xlsx files you just provided and both work just fine.. using "insert object"
Message 20 of 65
in reply to: mcgyvr
Didn't have problem until yesterday, I now have the same problem, no chart in pdf after exporting.
