Inventor Forum
Export Face to DXF
4 REPLIES 4
lkirit2000
2487 Views, 4 Replies
Export Face to DXF
I did a lot of Export Face As to usual parts no problem.
Please see the attached CAD file, my purpose is to create a dxf file for these texts to laser cut and batch marking. I my attachment when I select the inner faces I couldn't get the " Export Face As " option.
Is there any other best way in Inventor ?
Rgds
4 REPLIES 4
IgorMir
in reply to: lkirit2000
Hi Kiri
That's because Inventor exports only one face at a time as DXF.
To get what you want - export the whole part as DWG, open it in AutoCAD, Explode, Delete all the unwanted faces, Save what you need as DXF. It is a cumbersome workaround, but for one off design it might work.
Cheers,
Igor.
Web: www.meqc.com.au
mikejones
in reply to: IgorMir
Create a sketch on the recessed part of the text and use 'Project Cut Edges' then export the sketch as dxf.
Mike
Autodesk Certified Professional
johnsonshiue
Hi! Another place is Inventor App store. There are quite a few tools enhancing the workflow. Please take a look.
https://apps.autodesk.com/INVNTOR/en/List/Search?isAppSearch=True&searchboxstore=INVNTOR&facet=&coll...
Many thanks!
Software Test Engineer
IgorMir
in reply to: mikejones
That's perfect!
Thank you, Mike.
Cheers,
Igor.
Mike
