I did a lot of Export Face As to usual parts no problem.
Please see the attached CAD file, my purpose is to create a dxf file for these texts to laser cut and batch marking. I my attachment when I select the inner faces I couldn't get the " Export Face As " option.
Is there any other best way in Inventor ?
Rgds
Solved by mikejones. Go to Solution.
Solved by IgorMir. Go to Solution.
Hi Kiri
That's because Inventor exports only one face at a time as DXF.
To get what you want - export the whole part as DWG, open it in AutoCAD, Explode, Delete all the unwanted faces, Save what you need as DXF. It is a cumbersome workaround, but for one off design it might work.
Cheers,
Igor.
Create a sketch on the recessed part of the text and use 'Project Cut Edges' then export the sketch as dxf.
Mike
Hi! Another place is Inventor App store. There are quite a few tools enhancing the workflow. Please take a look.
Many thanks!
That's perfect!
Thank you, Mike.
Cheers,
Igor.
Mike
