Inventor Forum
Error; problems encountered while saving the document
25 REPLIES 25
Message 1 of 26
23572 Views, 25 Replies
Hi, I have a problem when I try to save a Document .idw into .dwg,
Appear this error
I have inventor 2008,
Could anyone know how to resolve it?
Regards, Andres.
25 REPLIES 25
Message 2 of 26
I could be anything from invalid characters in the file name to directory
permisions you are saving to, to an actual problem with the file it's self.
IV2010-Pro-sp2
Vista Business 64bit Sp2
Core i7 950 @ 3.07Ghz
12Gb DDR3-1600, 240Gb (4 x 60 Gb SSD - RAID0)
Quadro FX3800 - 191.66
SpacePilot 3.8.1 / 6.8.1
AVG9.0
"cachimba" wrote in message news:6310571@discussion.autodesk.com...
Appear this error
Regards, Andres.
Message 3 of 26
JDMather
Can you attach the file here?
Have you installed all Hot Fixes and Service Packs?
Is this a new problem, does it work with other files?
Have you tried rebooting.
Message 4 of 26
did anybody find a solution for this one of our clients is facing the same problem
Message 5 of 26
JDMather
More information is needed.
You have not even answered the 4 basic questions posted above.
Is your client still using Inventor 2008?
What operating system and system specs.
(there will likely be more questions as well, but these form a start to defining the problem)
Does File>Save Copy As work?
Is this the first time save or is there an earlier state save?
Oldversions file?
Message 6 of 26
support
in reply to: JDMather
our client is working with
Product Design Suite Ultimate 2013
All fixes installed
all other files save without any problem it only if the user tries to save the file in Autocad .dwg format this error comes up.
regards
Prem
Message 7 of 26
JDMather
in reply to: support
Only this file as dwg or any file as dwg?
Drawing or part file?
(the original post says *.idw)
Can it be saved in some other format and attached here so that others can attempt to reproduce the error?
Message 8 of 26
support
any idw file saved as AutoCAd dwg file produces this error.
Message 9 of 26
blair
Try the "Save Copy As" instead of the "Save-As"
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 10 of 26
tried save a copy as as well as export option, none of them work, it is just that it does not convert a idw file to an AutoCAD dwg tried almost all methods.
Message 11 of 26
Martin_Goodland
We used to see this when using 32bit version of the software when the OS would run out of address space. Are you using the 32bit version of 2013 ?
Inventor 2023
Message 12 of 26
blair
in reply to: Martin_Goodland
Unfortunately, all the poster has given us is that he is on IV2008. Numerous requests for more system information from this user go unanswered.
I wish there is some way one can remove themselves from a post as not to waste anymore time with people that can't answer requests for additional system information.
Delta Tau Chi ΔΤΧ
Message 13 of 26
SBix26
in reply to: blair
Blair, we've got two threads here: the old one from 2-1/2 years ago, and the new one from three days ago.  Prem (also posting as "Support") has answered most of JD's and your questions, now.
But I think all you have to do to remove yourself from notifications for this thread is unsubscribe (can't tell you how, since I haven't had to do it yet).
Message 14 of 26
support
in reply to: SBix26
Got the solution to this through the Autodesk Support Group, Just needed to reinstall DWG Review 2013 and update 2 for Inventor 2013, this was the culprit as it carries the dwg conversion dll's.Smiley Happy
Message 15 of 26
CAD-One
When I got this issue, I went to "Get Started" -> "Projects" and obviously it was pointing to some junk file in "Temp".
I cancelled out & make sure it points to correct ipj file.'
I was able to save.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
Message 16 of 26
Hello.
Autodesk Design Suite 2013 x64
I updated everything - SP2 + update for inventor
Also the Design Review and True View were reinstalled.
Still, I get the message "Problems encountered while saving the document" when I save as copy in AutoCAD DWG or export as DXF.
Please, help.
With kind regards,
                                    Alex
Message 17 of 26
CAD-One
Check if the project file is set to different one.
Sent from my iPhone
C1
AutoCAD 2020
Message 18 of 26
I used this solution. Unable to Save As or Import DWG/DXF
Issue:
Save as DWG, Save as DXF results in:
  • Clicking [Option…] button doesn’t open the dialog box.
  • Error message is shown when clicking [Save].
  • No file is generated.
User-added image
Import DWG / DXF results in:
  • Nothing happens. (Open works by clicking [Options..] > select “Import” > [OK] > [Open].)
  • File is not imported.
  • No error message is shown.
Causes:Inventor is not fully registered.
Solution:
  1. Press [Windows] key to open the Windows' start page.
  2. Type cmd. Right-click Command Prompt and select "Run as administrator."
    User-added image
  1. On "Administrator: Command Prompt" window, type cd "c:\program files\autodesk\Inventor 2014\bin" > press Enter. Then type inventor /install > press Enter.
User-added image
  1. Wait for 1 minute. (Inventor will run in the background and then exit silently.)
Message 19 of 26
thank you v. much, your last soln. worked like a charm.
Message 20 of 26
is there a reason why i don't ever see the save as DXF as an option in Inventor 2014? (although this solution did work to fix the save as DWG option, thx!)
Technology Administrators
