Inventor Forum
Error; problems encountered while saving the document
25 REPLIES 25
Message 1 of 26
24199 Views, 25 Replies
Hi, I have a problem when I try to save a Document .idw into .dwg,
Appear this error
I have inventor 2008,
Could anyone know how to resolve it?
Regards, Andres.
25 REPLIES 25
Message 21 of 26
When the dwg doesn't work, option dxf doesn't work also. I use dwg because i draw on Autocad.But also works dwg.
Message 22 of 26
DWG is the native format of AutoCAD / Inventor, DXF is more used to transfer the drawing to other programs, such as 3dstudio, coreldraw, etc. The problem when you import a DXF generated by these programs is that it loses information such as layers, blocks etc.
Message 23 of 26
I have the same problem, i've done the solution you propose but
the problem continue. Also i intalled the updates to Inventor 2018.
Any suggestion.
Regards
Message 24 of 26
blair
Make sure when you are saving your Inventor drawings, you are using the correct DWG format. There are two DWG options, Inventor DWG and AutoCAD DWG. Make sure that you are using the AutoCAD DWG option from the drop-down list when saving.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 25 of 26
johnsonshiue
Hi! Please share an example exhibiting the behavior here. Your case may be different than the original thread. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 26 of 26
AAFMALIT
in reply to: johnsonshiue
Three time, my solution was at command line, run "c:\program files\autodesk\Inventor 2013\bin\inventor" /install.
