Scott Moyse
Product & Platform Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Scott Moyse
<scottmoyse> wrote in message news:6283912@discussion.autodesk.com...So,
i have a whole load of parts in an assembly, and there are sketches in these
parts, on these sketches are geometries that have been projected from other
parts in the assembly. So they are cross part references.
Initially
the sketches and the respective parts were adaptive. When i made changes the
references updated etc..
However, for some reason the adaptivity has
been turned off, and the option is greyed out. As a result the cross part
projections on the sketches don't update but don't throw any errors either. So
if i delete them and try to re-project them, Inventor tells me that the part
is adaptive in another assembly and the cross part projection
failed.
This simply isn't true, i don't have any other assemblies, and
it worked fine last week when i created the assembly.
Trouble is the
error message doesn't give me any direction it tells me something is wrong. Is
there anyway of finding out how many assemblies inventor thinks the part is
in? or clearing/resetting adaptivity on the part itself so i can start re jig
everything without havin gto recreate the offending parts?
note: some
of the parts in the assembly are fine, its only a couple that are being
problematic.
The data set is MASSIVE so i would rather not post it
just yet.
I'm tearing my hair out on this one, anyy help would be
appreciated.
cheers
Scott Moyse
<scottmoyse> wrote in messageThats
href="news:6284354@discussion.autodesk.com">news:6284354@discussion.autodesk.com...
pukka mate! seems silly that an adaptive tick option is in two locations, this
one and under the occurence tab in the iproperties of the part when accessed
from the browser tree in the assembly. I had been told this other tick box
existed but none of us could find it, so thanks for that. I've needed it a few
times now and in the past have just had to remake the part from
scratch.
You have saved 50% of my rework to fix this. Trouble is now i
can clear the adaptivity properly the references in the sketch disappear but
the geometries remain with projected constraints, as they would appear if you
projected each edge individually instead of projecting the face. However, they
still don't adjust, presumably because they have lost the link path back
through to the source part via the assembly.
What i don't understand,
is how sporadic this problem has occured, in 1 assembly it has only happened
to 2 of 15 parts that were adaptive. In another assembly every single part
that was adaptive in that assembly now isn't, but is still adpative within
itself. And the rest of the project all of the assemblies and adaptive parts
work great.
Any ideas on how to deal with
this?
Scott Moyse
<scottmoyse> wrote in messageSorry
href="news:6284444@discussion.autodesk.com">news:6284444@discussion.autodesk.com...
i used US because i asked my colleagues if they knew where that setting was,
as one of them mentioned it existed a few months ago. I am the only one with
read/write access to these parts and the only one who has been working on
them. I definately would have considered this otherwise.
With regards
to the option being in two places. Why can't the occurance tab appear in the
iProperties of the part, when you access the iProps from the part. That way it
would only be in one place and you could achieve the same thing.
The
occurance tab doesn't appear in the iProps of the assy but only appears in the
iProps of the part when you access them via the assy browser and right click
on the part node.
I understand why you guys have done what you have,
but it seems it could be done in one area that appears in two
places.
Either way i know its there now so it makes no difference to
me.
butt... I still have this problem.
It's looking more and
more like i need to pack and go the data set and send it to tech
support.
Scott Moyse
