Do we have embossing feature on taper curved face?
We are getting below while trying to do this.
Thanks for your response in advance.
Regards
Abhiranjan Sudhanshu
ak.sudhanshu@integratedww.com
Solved by SBix26. Go to Solution.
Yes, but your workplane has to be parallel to that face.
If you can't figure it out you could attach your file here.
It looks like you selected "wrap to face".
Deselect it and make sure the emboss is in the right direction.
It should work after that.
Good luck!
Ok, in that case do what @Anonymous said.
1. Create a plane parallel to the face the emboss has to go to
2. Sketch the name on that plane and emboss with wrap to face.
Good luck!
I did tried that too. I made a tangent Plane with face and then had text on that plane.
https://drive.google.com/open?id=0B04OHOZH8av4cG5GVFhHNG5MdGc
Still, there is an issue. Additionally, I am not getting correct orientation of Text. Text is coming as mirrored text.
See attached file.
The problem with the orientation is that you are sketching on the wrong side of the plane.
The problem with the embossing, I think, is because of your workplane is laying within the part. It wasn't tangent to the face.
Here you go
Create a workplane. Workplane > Click the intersection point from that sketch and edge of the part > Click the tapered face
Next create a sketch on the workplane and type your text.
Last Emboss!!!
I am done now. I have fixed the text oientation by using Geometry Text.
I have kept the plane tangent to the tapered Face.
Thanks to all for your kind support.
The fix for your text orientation issue is simply to reverse the workplane normal: right click on the workplane and choose Flip Normal. Now the sketch is on the correct side of the plane so your text reads properly.
Sam B
Inventor Professional 2016 R3 SP2
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
