Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Inventor Forum
Embossing on Taper curved Face
16 REPLIES 16
Message 1 of 17
1083 Views, 16 Replies
Do we have embossing feature on taper curved face?TAPER CURVED FACE -1.JPGTAPER CURVED FACE -2.JPG
We are getting below while trying to do this.
Thanks for your response in advance.
Regards
Abhiranjan Sudhanshu
ak.sudhanshu@integratedww.com
16 REPLIES 16
Message 2 of 17
Yes, but your workplane has to be parallel to that face.
If you can't figure it out you could attach your file here.
Message 3 of 17
Frank-Oosterwaal
It looks like you selected "wrap to face".
Deselect it and make sure the emboss is in the right direction.
It should work after that.
Good luck!
Message 4 of 17
in reply to: Frank-Oosterwaal
It should be Wrap to Face as per requirement.
Message 5 of 17
Frank-Oosterwaal
Ok, in that case do what @Anonymous said.
1. Create a plane parallel to the face the emboss has to go to
2. Sketch the name on that plane and emboss with wrap to face.
Good luck!
Message 6 of 17
I did tried that too. I made a tangent Plane with face and then had text on that plane.
TAPER CURVED FACE -4.JPGhttps://drive.google.com/open?id=0B04OHOZH8av4cG5GVFhHNG5MdGcTAPER CURVED FACE -5.JPG
Message 7 of 17
Still, there is an issue. Additionally, I am not getting correct orientation of Text. Text is coming as mirrored text.
Message 8 of 17
See attached file.
The problem with the orientation is that you are sketching on the wrong side of the plane.
The problem with the embossing, I think, is because of your workplane is laying within the part. It wasn't tangent to the face.
Message 9 of 17
I am using Product Design Suite Utlimate 2015
Message 10 of 17
Ok sorry wait a sec
Message 11 of 17
Thanks Tniens, But I have Lower version (2015) at my end, so can't open your file.
Message 12 of 17
Here you go
Create a workplane. Workplane > Click the intersection point from that sketch and edge of the part > Click the tapered face
Next create a sketch on the workplane and type your text.
Last Emboss!!!
Message 13 of 17
I tried by playing the location of plane. 1st I took on the tangent edge, then Outside of part as parallel plane to the tangent edge and then inside the part (Parrallel)
Message 14 of 17
Try to do it like in my previous post
Message 15 of 17
I am done now. I have fixed the text oientation by using Geometry Text.
I have kept the plane tangent to the tapered Face.
Thanks to all for your kind support.
Message 16 of 17
SBix26
The fix for your text orientation issue is simply to reverse the workplane normal: right click on the workplane and choose Flip Normal.  Now the sketch is on the correct side of the plane so your text reads properly.
Sam B
Inventor Professional 2016 R3 SP2
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
Message 17 of 17
in reply to: SBix26
This options works too.
