Inventor Forum
Drawing Tolerance Method Text Not Scaling With Styles
2 REPLIES 2
stothZS4NS
251 Views, 2 Replies
Hi there, I am looking for a solution to certain text not scaling with my styles text size. As seen in the picture, we have two different text sizes, I need only one. I am using a scaled down text size through the styles editor for A sized sheets of paper, but it does not change the tolerance text size. Am I scaling my text size wrong when using A sized documents?
2 REPLIES 2
Gabriel_Watson
in reply to: stothZS4NS
Right-click those problem dimensions and select "Edit Dimension Style...", then pick the filter to "Active Standard" and go to your dimension standard's "Text" tab, and see if the tolerance text is set to use the primary text style and its size:
stothZS4NS
in reply to: Gabriel_Watson
Hi, Thanks for the reply. This is a solution. All of my text is now at the correct sizing. Thanks for your time.
Technology Administrators
