Hi there, I am looking for a solution to certain text not scaling with my styles text size. As seen in the picture, we have two different text sizes, I need only one. I am using a scaled down text size through the styles editor for A sized sheets of paper, but it does not change the tolerance text size. Am I scaling my text size wrong when using A sized documents?
Solved by Gabriel_Watson. Go to Solution.
Right-click those problem dimensions and select "Edit Dimension Style...", then pick the filter to "Active Standard" and go to your dimension standard's "Text" tab, and see if the tolerance text is set to use the primary text style and its size:
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Hi, Thanks for the reply. This is a solution. All of my text is now at the correct sizing. Thanks for your time.
