drawing slow performance using sketched symbols with images - Inventor 2024
bradeneuropeArthur
Mentor Mentor
Message 1 of 8
bradeneuropeArthur
Anybody familiar with the fact of drawing slow performance using sketched symbols with images.
Our drawings become slow after using sketched symbols with images.
@johnsonshiue maybe you have an idea?
@bradeneuropeArthur - I have added the product & release to your post title - Thank you! - CGBenner
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (7)
Message 2 of 8
johnsonshiue
Hi Arthur,
I vaguely remember there was an issue like this. But I don't remember what was the conclusion. It could be related to OLE linking. If possible, please share an example that exhibits the poor performance with me directly at johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 3 of 8
CGBenner
@bradeneuropeArthur
Hey Arthur.  What version of Inventor are you seeing this in?
Chris Benner
Message 4 of 8
bradeneuropeArthur
Good day Chris,
we are using Inventor 2024.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
bradeneuropeArthur
Just send you both a personal email to your Autodesk address.
Thanks in advance.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 8
johnsonshiue
Hi Arthur,
Many thanks for sharing the file! I am able to reproduce the behavior. Something is wrong indeed. It seems to be specific to sketch symbols containing an image in an Inventor dwg file. The same behavior does not seem to happen in an Inventor idw file. You may save the dwg file as an Inventor idw. Saving will be swift.
I need to work with the project team to understand the issue better. I will get back to you with my findings.
Thanks again!
Message 7 of 8
johnsonshiue
Hi Arthur,
So far the project team has confirmed that it is specific to OLE objects in Inventor dwg files (not idw files). There is definitely room for improvement.
Many thanks!
Message 8 of 8
CGBenner
@bradeneuropeArthur  @johnsonshiue
Thank you Johnson for the update!  Even though this doesn't really solve the immediate problem, I am marking it as a solution so that others can find it and see what you have identified as the problem so far.
Chris Benner
