Inventor Forum
Drawing Dimensions different than part Dimensions???
4 REPLIES 4
706 Views, 4 Replies
For some reason the dimensions generated in the drawing file are different than the part file on one cut. This isnt a tolerance or rounding error. The rest of the parts dimensions pulled in the drawing are correct. Thanks ! Inventor dimension.png
4 REPLIES 4
SBix26
Right click on your drawing view and hover over General Dimension Type >.  Which one is checked, Projected or True?
Can you post your part and drawing?  What version of Inventor are you using?
Sam B
Inventor Professional 2018.1.2
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Xun.Zhang
It seems works well in my end with a sample file, is there any difference between my data and yours? if so, would you mind send the data to me for a further debugging to see how it happens like this in your side.
Xun
in reply to: SBix26
It was projected. Ive never changed those settings. Im not sure why it changed? Changing back to True solved the problem. Thanks so much. I would have never looked there.
Ross
SBix26
Projected is almost always the correct one to use, and certainly should be the default.  When you're looking at a view with features at different depths, the True dimension will be misleading at best, or just plain wrong.  For instance:
The view to the right (3rd angle projection!) is set to True, which is not the least bit helpful and could end up with a scrap part.
Sam B
Technology Administrators
