I would like to see section view of selected part.
Is it possible to do like attached image?
Thanks a lot in advance.
Unfortunately, after confirmed with section view expert in our team, it's still a limitation for section view currently.
However, there is a workaround to leverage Assembly feature - Cut extrude and controlled by suppress feature suppression and adding/removing participates to create a similar view.
Below is a sample video for you to understand more.
Here's a possible workflow to achieve your desired result in a DRAWING environment.
Here are the step I too to get the sectioned iso view.
