section view in assembly
toznal
toznal
I would like to see section view of selected part.
Is it possible to do like attached image?
Thanks a lot in advance.
Xun.Zhang
Unfortunately, after confirmed with section view expert in our team, it's still a limitation for section view currently.
However, there is a workaround to leverage Assembly feature - Cut extrude and controlled by suppress feature suppression and adding/removing participates to create a similar view.
Below is a sample video for you to understand more.
Xun
mpatchus
Here's a possible workflow to achieve your desired result in a DRAWING environment.
Here are the step I too to get the sectioned iso view.
  1. Create TOP view of assembly
  2. Define SECTION view
  3. Select the desired components that you wish to remain whole, and set SECTION PARTICIPATION to NONE
  4. Project section view
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
