Do step files have material in them?
johan.degreef
Advisor Advisor
johan.degreef
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
-niels-
I opened 2 different step files with notepad and it contains the following:
I'm guessing this comes from iProperties, so i'm inclined to say step files contain material info.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
CCarreiras
Hi!
I believe the step files would have the appearance (Color), but not the material info.
When converting to Inventor, You have to reapply the material to have the physical properties available.
CCarreiras
JDMather
The short answer is Yes.
Err, maybe...  All I am getting is name and Density outside of Inventor.
But when I open the STEP in Inventor I get all of the Material Properties.
Use 214 or 242.
Unfortunately not all CAD software can pick up the Material information...
And of course - as mentioned previously Material (properties) and Appearances are two different things.
And of course - you can do your own simple experiment within Inventor and with other software opening the STEP file.
I guess I should have matched up the Units in my test, but you get the idea - you can run a test.
johnsonshiue
Hi! Yes, I believe material styles are always supported in the STEP format itself. Inventor started supporting material styles in STEP translation in 2022 or so.
Many thanks!
Software Test Engineer
