Distance from face
Distance from face
Message 1 of 33
Distance from face
Dear Expert,
How to use the distance from face option in the extrude command? New version: 2020. Please see my screenshot below.
Many thanks.
Ngoc Son
Replies (32)
Message 2 of 33
SBix26
Post your file here, forum experts can help figure it out.
Sam B
Inventor Pro 2020.0 | Windows 7 SP1
LinkedIn
Message 3 of 33
YuhanZhang
You can find the help about how to use this option to create extrude feature:
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-084A5063-64E2-454A-8F48-6794EBCFD683
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 4 of 33
Hi
Message 5 of 33
Please see my attached files.
Message 6 of 33
YuhanZhang
I will forward this to proper team to look into it and back to you later.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 7 of 33
Many thanks
Message 8 of 33
YuhanZhang
We have this issue tracked with INVGEN-27935, you can query its status with this number.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 9 of 33
Ok thanks, . Hope we can do it soon!
Message 10 of 33
massimo_leide
yes you can
watch screencast
Message 11 of 33
marcin_bargiel
What's the status of this problem? INVGEN-27935
I've got similar problem with extrusion form cylinder...
Many thank's
Marcin
Vote for REPLACE VARIES !
REPLACE VARIES
Message 12 of 33
johnsonshiue
Hi! Based on the status of INVGEN-27935, it has been fixed as of 2020.1 update. Have you installed the update?
Many thanks!
Software Test Engineer
Message 13 of 33
marcin_bargiel
Sorry, i can't find it all 2020 updates that it was fixed.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
Where do you get this information ?, give me source please
I uninstalled 2020.1 and 2020.1.1 updates because they have spoiled more for me than they have repaired :]
Do You remember this ? i couldn't export good quality drawing to pdf.
https://forums.autodesk.com/t5/inventor-forum/export-xls-table-to-pdf-inventor-2018-problems/m-p/907...
Finally ! i confirm that this issue was NOT fixed on all last updates ! (tried on another PC)
I tried files from son.lengoc (message 5)
Please investigate my file END.TOP.ipt
N18_repad_end_top_1, N19_repad_end_top_1 (i cant use EXTEND FACE to start feature)
Moreover if these two reinforcement pad interfere each other - i have an error.
Funny thing is that (re-pad which i designed before 2018) works as expected ! N16_repad_end_top_1, N17_repad_end_top_1. If these two reinforcement pad interfere each other - there is OK.
I lost a LOT of hours to find the error, than i gave up and  converted the model and I do not use this function (distance from face) any more. Thank You !
More than a year has passed and and nothing has changed...
REPLACE VARIES
Message 14 of 33
johnsonshiue
Hi Marcin,
I think there is a bit confusion here. INVGEN-27935 is indeed fixed as of 2020.1 update. It was not listed in readme because it was found internally. I am still checking with the project team to understand the issue better.
Many thanks!
Message 15 of 33
YuhanZhang
Can you provide a video to show what you want to do with your data? The defect was fixed in Inventor 2020.1, if with your data still has problem to create the extrusion there maybe something different, we want to make sure we are talking about the same thing.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 16 of 33
marcin_bargiel
Attached 2 videos, one with data son.lengoc (message 5) (Distance from face 2019.ipt and Distance from face 2020.ipt), a second one with my END_TOP.IPT.
As You can see, defect was NOT fixed (in both cases there are errors), I have update 2020.1 and 2020.1.1.
REPLACE VARIES
Message 17 of 33
marcin_bargiel
"It was not listed in readme"
I can't understand, how do we users know that something has been corrected, how difficult is it to write it to the update readme file?  this explanation doesn't get to me - somewhere there should be information :]
Once again the question - where can the user check the status of the error? Please link to the page.
Thank You.
REPLACE VARIES
Message 18 of 33
johnsonshiue
Hi! I suspect we have separate issues here. The one shown by OP here is not yet fixed on any 2020 update, including the coming 2020.2. But, it seems to be fixed in the latest internal build for future release.
The issue here is that the cases could be geometry specific. It is difficult to describe the specific issue in words without showing the exact geometry.
I am sorry for the confusion.
Many thanks!
Message 19 of 33
johnsonshiue
Hi Marcin,
I was using the wrong build when I made the comment above. I was wrong. This particular case is indeed resolved as of the latest build targeting 2020.2 update. There will be a testable build available on Inventor Beta site soon. You can try it out.
Many thanks!
Message 20 of 33
marcin_bargiel
"This particular case is indeed resolved as of the latest build targeting 2020.2 update."
Watch my movie please, this was NOT RESOLVED in the latest built 2020.2 😕
Very simple case : circle to cylinder :], function extrude from face introduced in 2018 is still useless...
https://autode.sk/2rp6AaQ
PS. What about my case ? from message 13? have somebody investigate it?
REPLACE VARIES
