Inventor Forum
discovered a solution to get modelstates in frame generator parts.
5 REPLIES 5
kesUPRHR
675 Views, 5 Replies
kesUPRHR
!warning! this method of creating modelstates for frames has not been fully tested and may have side effects.
This method uses the demote function to make a subassembly that can have modelstate and then placing it the assembly where the frames are needed.
these modelstates can be created and edited the same way as any other modelstate
Steps to create result.
Step 1: Demote frames
Step 2: save the new sub assembly and place it into other assemblies where they are needed
and that is basicly it.
Result after creating modelstates:
5 REPLIES 5
johnsonshiue
in reply to: kesUPRHR
johnsonshiue
Hi! After the frame members are demoted, the associativity between the members and the skeletal part will be broken.
Many thanks!
Software Test Engineer
Many thanks!
Curtis_Waguespack
These are some tips and techniques that Pete developed & refined to help illustrate Inventor workflows, overcome design challenges and provide workarounds fo...
Learn how to create multiple frame designs from a single skeletal model by leveraging the power of Model States in Inventor. With each Model State having distinct parameter values for frame sizing, you can achieve flexibility and efficiency in your design process. See real-life examples and ...
kesUPRHR
in reply to: johnsonshiue
kesUPRHR
hey @johnsonshiue
is there a way to see if the associativity have been broken and what would the consequences be ?
thanks in advance
hey @johnsonshiue
thanks in advance
kesUPRHR
kesUPRHR
i don't see anything that is broken and there are no warnings anywhere not even when i am demoting. also my frames function as they normally would.
johnsonshiue
johnsonshiue
Hi! If it works for your case, that is great. But based on the way Frame Gen works, unless there is a dedicated Frame Gen Demote command, such operation can lead to associativity breakage.
Many thanks!
Many thanks!
