direction face in sheet metal
MIRKO_G
Message 1 of 9
MIRKO_G
Hello everybody.
I notice a problem in the inventor sheet metal environment by performing the following operations:
- New sheet metal part
- I create an offset plane from the central plane
- I mirror the plane just created and as a reference I use the central plane
- On this last plane, I create a sketch and apply the Face function
The preview shows me a direction of application of the thickness, while at the time of creating the solid, the direction appears to be the opposite.
I found this thing only in the sheet metal environment (not with extrusion) and on the 2022, 2021 and 2020 versions.
Do others find this anomaly?
I attach example in 2022 version and images.
Autodesk Inventor 2015 Certified Professional
Autodesk Inventor 2018 Certified Professional
Autodesk Certified Instructor - Platinum
Replies (8)
Message 2 of 9
bradeneuropeArthur
I see the same and that is not correct.
@johnsonshiue Would it be possible that you investigate this with the development team to see how this can be solved.
Thanks in advance
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
gmwi
I'm on '21 and it does as it should. You might want to check your settings. Send the example in a ver '21 and I'll see if I can find it. I don't have that problem.
Message 4 of 9
bradeneuropeArthur
I have seen various changes in Inventor 2022.
This could be possibly one of them!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
johnsonshiue
Hi Mirko,
How are you doing? This is an interesting find. I am able to reproduce the behavior in all releases on my machine. It is not unique to 2022. This has something to do with the default direction of a Face. In theory, like Extrude, it should default to the normal direction of the sketch (workplane). In this case, the normal direction is the opposite. I cannot explain the behavior. I will work with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 6 of 9
MIRKO_G
I am attaching the file in the 2021 version.
Message 7 of 9
bradeneuropeArthur
@johnsonshiue wrote:
Hi Mirko,
Many thanks!
That would be great @johnsonshiue
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 9
gmwi
Problem solved sort of. The glitch is with the mirrored function. When you just offset a plane to the same distance then it works as normal. Your sketch is taking direction flow from the referenced plane. That's an approach that I normally don't use. I generally work with created plane and then mirror the features. If you change that procedure then it should be smoother for you.Face Dir2 Correction.jpg
Message 9 of 9
gmwi
I forgot to ask if your in Australia or Ireland. Things are backwards in those counties.
