Inventor Forum
Dimensioning a J Slot that is Wrapped around a Tube
4 REPLIES 4
anasdin
204 Views, 4 Replies
Screenshot 2024-07-26 105005.pngHow would I dimension the attached item showing the right information about the 'J Slot' to a machinist?
Labels (3)
4 REPLIES 4
kacper.suchomski
in reply to: anasdin
Hi
What dimensions do you want to include?
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
anasdin
in reply to: kacper.suchomski
That's my problem, I don't know what dimensions to include. If it was a basic slot that would be easy. I have attached another photo, are the details I have shown enough/correct?
kacper.suchomski
You have closed the dimension chain several times, which is unacceptable in a technical machine drawing:
  1. You need to remove one dimension of 17.5 and add the dimension of the entire length.
  2. R5 and 10 are the same information - cannot be repeated.
  3. 20 and 25 are the same information - they cannot appear together.
  4. In the cross-section, the angular dimension is sufficient.
In addition:
  1. The groove is non-technological - it cannot be made with a fi10 milling cutter.
Kacper Suchomski
anasdin
Thank You for that explanation. I know some of the dimensions are repeated, missing some. My main problem was understanding that the angular dimension was the important one.
Its OK for this to be non-technological, it was a test part for my own education.
Again, thank you for the quick response.
