How would I dimension the attached item showing the right information about the 'J Slot' to a machinist?
Solved by kacper.suchomski. Go to Solution.
Hi
What dimensions do you want to include?
Kacper Suchomski
That's my problem, I don't know what dimensions to include. If it was a basic slot that would be easy. I have attached another photo, are the details I have shown enough/correct?
You have closed the dimension chain several times, which is unacceptable in a technical machine drawing:
In addition:
Kacper Suchomski
Thank You for that explanation. I know some of the dimensions are repeated, missing some. My main problem was understanding that the angular dimension was the important one.
Its OK for this to be non-technological, it was a test part for my own education.
Again, thank you for the quick response.
