Difficulties with Equation Curves
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having difficulties constructing a Haack series nose cone profile in Inventor.
To give a brief background, Haack series nose cones are profiles closely related to airfoils which are described by equations. A basic overview of the equations is here, and I'm attempting to construct the von Karman variety where C = 0.
I'm attempting to construct a profile with a base radius of 12.5 mm and a length of 30 mm, so my equation was as follows:
y(x): (12.5/sqrt(PI))*sqrt((acos(1-((2*x)/30))-(0.5*sin(2*(acos(1-((2*x)/30))))))
iterated from xmin to xmax over 0 to 30 mm.
Checking this in a online graphing calculator gives the correct profile and behavior that I'm trying to use. This is the correct version of the curve:
However, Inventor responds with the following:
This is obviously incorrect for a number of reasons:
- Some weird offset is being applied to the zero point (8.51 mm).
- The height of the curve (the difference between the thickest point and thinnest point) is not 12.5 mm.
- The curve is in the wrong quadrant (-x,-y as opposed to positive x and y quadrant).
I've attempted to:
- Double-check the equation. I know that I may not have coalesced the multiple equations into a single line correctly, and then entering it into a text-based, non-pretty-printed format opens up the possibility for errors. However, I cannot find something readily apparent with the equation that appears wrong, and permuting it in a calculator shows that numerous single errors (omitting a coefficient, etc.) would still create a curve in the ballpark of being correct.
- Toggle the degrees/radians unit preference in Document Preferences, just in case Inventor was interpreting the trigonometric functions incorrectly. No effect in either case.
I haven't tried to offset the curve by the odd amount (8.51 mm), because that wouldn't address the other two issues. I have no idea where that value is coming from - it appears to just be a peculiar number. I do have the feeling that there is an obvious mistake here, however, so I'm not ruling out that all this was a novice error.
Finally, for future reference, how do I "spot" the equation curve, as in define its start point? In this project I'm going to be using multiple equation curves with precise "landing points". How do I define a specific reference for where the curve begins? The equation curve tool, while useful, doesn't appear to have many configuration options.
