Unwanted transparency when rendering
     I have an assembly, when I render it, one of the parts renders semi transparent (the red part in the image) which I don't want. The part is imported from a supplier website. Can I stop this happening? Thank you
johnsonshiue
Hi! Without seeing the actual files, it is hard to tell where the problem is. I guess you can find the transparent body in Solid Bodies folder -> right-click on it -> Properties  -> check "Clear all appearance overrides."
Does it work better now?
Many thanks!
Software Test Engineer
Thomas_Savage
Hello @Anonymous
I use to get this. i think it is just that colour red which is transparent. I started using a different red, and it was fine.
Try with a different colour, is it still transparent?
Thomas.
Thomas Savage
Design Engineer
Hi, Awesome! Problem sorted! It seems 'dark red' turns transparent when rendered. "Orange red' is almost similar and did not turn transparent.
Thank you!!
Thomas_Savage
You're welcome @Anonymous
Thomas Savage
Design Engineer
