- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've got a question about the thicken/offset tool and wanted to see if anyone has any ideas to help out. To put some context into this as well, I primary use Inventor to design for large format additive manufacturing. I often design to oversize the parts because we are doing some secondary finishing of the parts. I often use thicken/offset to enlarge the parts but this doesn't always give the result I'm looking for.
Its my understanding that the thicken/offset tool creates a new surface that is a set distance normal to the surface being offset. By normal, I mean perpendicular to the surface in all 3 axis directions. I would like to do an offset that that is only normal to the surface on cross sectional planes that are normal to a selected axis. To do this manually, I could create a loft from multiple offset cross section sketches but this can take a significant amount of time and can be very tedious when dealing with certain geometries.
For example, in the attached model I have a half dome shape that has a 36in radius. I can easily create a thicken/offset surface from the dome that is 2in inside of the current surface but this is not what I need. To get what I'm looking for I can manually create planes, then sketches on each plane and project cut edges, then offset those lines, then use those lines to create a loft of the new dome. This isn't perfect but with enough planes and sketches it can be very close to the original surface.
Does anyone one have any ideas on how I could accomplish this in an automated fashion? Could I use the existing in a different way to do this? If it needs to be created manually, I'd like this to work on any geometry and have a selectable level of detail for the number of planes to create (or the distance between them), the offset desired for each sketch and the normal axis to use.
I've already considered using shell but it creates the new surface the same way thicken/offset does. I have also thought to copy and move a surface unidirectionally, to create the offset, but this is very limited in the geometry it can be used for.
I've attached some pictures as examples and a model for reference.
