Inventor Forum
Detail views not visible anymore
5 REPLIES 5
b.graaf
194 Views, 5 Replies
For some reason my detail views in one particular drawing are not visible anymore!
In previous versions of this drawing they were still visible, but now, I only see the label of the detail view, but no model edges.
I have noticed that the model in the browser doesn't have a blue icon, but a transparent one.
Under Right Mouse Button I do not see any kind of option to turn on visibillity or something...
Is there anybody who has an idea what is the case here?
5 REPLIES 5
blandb
in reply to: b.graaf
Curious, do you have the part off in the assembly? If it is, and you turn the visibility back on, does the items show back in the views? If this is happening, check to see if this box is checked:
if it is, you can uncheck it, and you should be able to control all visibilities of all parts per view.
Autodesk Certified Professional
b.graaf
in reply to: blandb
Actually this has been modelled as a part instead of an assembly, so nothing has been made invisible in the model.
Also there are no design views....
I am ware of the link option. I have never seen this behaviour in a detail and I did never see the "transparent" icon of the detail in the browser...
NigelHay
I've had little anomalies like this in the past & found that, if you grab the centre of your call-out circle with your mouse & move it a small amount, the detail view magically reappears.
blandb
in reply to: NigelHay
Have you "attached" your detail circle to some geometry so it will stay associated with it?
johnsonshiue
Hi! Something isn't working right. Is the part far away from the origin? Please share the files (in zip) that reproduce the behavior here or send them to me directly johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
