For some reason my detail views in one particular drawing are not visible anymore!
In previous versions of this drawing they were still visible, but now, I only see the label of the detail view, but no model edges.
I have noticed that the model in the browser doesn't have a blue icon, but a transparent one.
Under Right Mouse Button I do not see any kind of option to turn on visibillity or something...
Is there anybody who has an idea what is the case here?
Curious, do you have the part off in the assembly? If it is, and you turn the visibility back on, does the items show back in the views? If this is happening, check to see if this box is checked:
if it is, you can uncheck it, and you should be able to control all visibilities of all parts per view.
I've had little anomalies like this in the past & found that, if you grab the centre of your call-out circle with your mouse & move it a small amount, the detail view magically reappears.
Have you "attached" your detail circle to some geometry so it will stay associated with it?
Hi! Something isn't working right. Is the part far away from the origin? Please share the files (in zip) that reproduce the behavior here or send them to me directly johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
