Derived Sketch Unable to Un-check
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
I have a Part that derives a sketch from  another part.
I cannot un-check this part after it has been derived.
It is also kind of greyed out as you can see in the picture.
What is the reason that I cannot un-check it?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
CCarreiras
Maybe... you're already using that sketch as a reference for a feature (?)
CCarreiras
bradeneuropeArthur
No everything has been deleted...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
johnsonshiue
Hi Arthur,
This could be a corruption. Please share the file here or send it to me directly johnson.shiue@autodesk.com. I would like to understand the derived sketch behavior better.
Many thanks!
Software Test Engineer
bradeneuropeArthur
Indeed this file is corrupted.
If you loop through the SketchEntities via the API you see that still two SketchEntities are ownedby some other SketchEntities.
I have inserted the i-logic code for you @johnsonshiue.
Could you please give us a solution to remove the sketch from the derive function.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
johnsonshiue
Hi Arthur,
I am sorry I don't think there is a way to "fix" the corrupted object. You will need to recreate it unfortunately.
Many thanks!
bradeneuropeArthur
Hi @johnsonshiue
Maybe there ia a way I am able to fix it via the API!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
