Cut length _ From bent pipes & other bent objects
drawingsCHR7R
Message 1 of 16
drawingsCHR7R
Hi guys,
I wanted to know: Is Inventor able to tell you what the cut length of a bent pipe or Round bar is?
For instance in the attache ipt. the pipe started out straight and was bent, would Inventor be able to give me a cut length of what it was prior to bending?
Replies (15)
Message 2 of 16
mcgyvr
Not totally.. Most just calculate or measure the neutral axis loop length and use that I believe.
You can get pretty darn close with that.
Message 3 of 16
Daan_M
I don't know any UI tool for this, but mabye there is....
Alternatively you could:
- Draw in splines and measure those, since pipe bending goes according to certain standards.
- Make an iLogic code that automates this
Example source:
Pipe bending calculation
Message 4 of 16
Here's an idea, if this is a "one off", and you need an accurate length, what about using the sheet metal environment?
Have a look at my screencast, the idea is to use a simulated square bar to represent the tube, which you then flatten, it should be quite accurate.
https://knowledge.autodesk.com/community/screencast/1eb8ee9b-dd75-406d-b82b-6702b7944a28
(for some reason the sound did not come through, but you can follow along on the video)
Message 5 of 16
johnsonshiue
Hi! The closest thing in Inventor is flat pattern or unfold in sheet metal. But, it may not apply to round tube. You may be able to approximate it using Unwrap in 2020 or later.
Many thanks!
Software Test Engineer
Message 6 of 16
johan.degreef
@drawingsCHR7R
Would added part be a solution for you?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Message 7 of 16
drawingsCHR7R
I see, could you please elaborate further on what the neutral axis loop length is?
I have an idea of what it is but I am not too sure.
Message 8 of 16
drawingsCHR7R
My normal methodology would be to use the arc length command in an idw. I will see about the workflow suggested and try it our. Thanks for the suggestion.
Message 9 of 16
drawingsCHR7R
@Anonymous I absolutely love this. definitely going to be using this. Thanks a lot!!
Message 10 of 16
drawingsCHR7R
@Anonymous I'm not too sure how to download the screencast. Would love to have it for future reference. How can I download it?
Message 11 of 16
drawingsCHR7R
Unfortunately not, but thank you for the attempt
Message 12 of 16
Message 13 of 16
LT.Rusty
Frame generator will do it quite easily for you right out of the box, but depending on what you're ultimately trying to accomplish it may wind up being too cumbersome.
On the other hand, it might also wind up being exactly what you need.
If you open up the zip file, there's a bunch of stuff inside it:
"bent part - FG ass'y.iam" is the main file.
"bent part FGSK.ipt" is the IPT file with the sketch on which the FG work is based.
The folder is automatically created by frame generator, along with everything inside it.
Open up the main assembly file, then you can drill down to the actual part that was created. Look at the parameters, and notice G_L, which stands for GENERATED LENGTH. (There's also B_L, for BASE LENGTH, but ignore that one for now. In this case it's the same as G_L, but in many cases (if not most) it won't be, and that can give you fits later on.)
By default, all these things are displayed in decimal with a ridiculous number of significant figures, but there's ways to fix that and make things show up with a set number of decimal places and / or fractional values. It's not difficult to do, but it is a little time consuming to set up initially, though it will make your life much, much easier in the long term if you're pulling G_L into drawings or part numbers or anything like that.
If these are standardized angles and bends, you could also create some custom content center parts that would have essentially similar functionality built in.
Rusty
Message 14 of 16
drawingsCHR7R
Thank you, It is essentially not what I had in mind as the work I do doesn't really require FG, but I do use it from time to time, so I will definitelty have a look at your suggestion.
Thank you
Message 15 of 16
dusan.naus.trz
try the file named BAR_UNFOLD.zip, which is in the link. Give feedback if this helps.
https://forums.autodesk.com/t5/inventor-ideas/round-bar-unfold/idi-p/9678931
Message 16 of 16
vyivanchikov
You can do it differently, if the profile is simple (round, rectangular... or other). Calculate through volume and area.
What is volume in maths, it is the area multiplied by the height (length).Therefore, from this formula to calculate the length is simply V/S (volume divided by area), which is the length.
In this example: the pipe is 76,2. The wall thickness is 3 mm. Area 689.894 mm2. Volume 1261192.9 mm3.
1261192.9 / 689.894 = 1,828.0965 mm.
Which corresponds to , if you look it up in the drawing, along the centre line.
Conclusion: if you do it through ilogic, introduce additional variables: area and volume.
Can be realised with the spring sweep too!
Good luck to all!
